Product
StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F
Quicklinx: 7NZKWS00 Mfr#: MDP2DPMF6IN
Length: 15.2cm
49 in stock
£11.32 ex VAT
£13.58 inc VAT
Connect your DisplayPort monitor to a standard Mini DisplayPort source.
The MDP2DPMF6IN Mini DisplayPort to DisplayPort video cable adapter allows you to add a standard DisplayPort connection port to your existing mini Displayport equipped laptop. Easy to use and install, this cost-effective solution makes it easy for you to go from Mini DP to DP, in order to get the most from your Mini DisplayPort device.
StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F - DisplayPort cable - 15.2 cm
DisplayPort cable
Length
15.2 cm
Connector
Mini DisplayPort - male
Connector (Second End)
DisplayPort - female
RoHS
DisplayPort cable
Shielding Material
PVC
American Wire Gauge (AWG)
32
Length
15.2 cm
Connector
20 pin DisplayPort - female
RoHS
Length: 15.2cm
Price Range Ex VAT: 0 - 50
