Convert a standard LP4 power supply connector to an 8-pin PCI Express video card power connector. The LP4PCIEX8ADP 6-inch LP4 to 8-Pin PCI Express Power Adapter converts a standard LP4 power connector on your existing power supply to an 8-pin PCI Express video card power connector, allowing you to install a PCIe graphics card without having to upgrade the computer power supply.
- StarTech.com 6in LP4 to 8 Pin PCI Express Video Card Power Cable Adapter - lp4 to PCI express - molex to 8 pin PCIe (LP4PCIEX8ADP) - power adapter - 4 PIN internal power to 8 pin PCIe power - 15.3 cm
- Power adapter
- Length
- 15.3 cm
- Connector
- 2 x 4 PIN internal power - male
- Connector (Second End)
- 8 pin PCI Express power - male
- Limited lifetime warranty
- Power adapter
- American Wire Gauge (AWG)
- 18
- Length
- 15.3 cm
- Connector
- RoHS
