Quicklinx: 7NZGWS00 Mfr#: LSATA6
Length: 15cm
Type: SATA
£3.34 ex VAT
£4.00 inc VAT
Secure latching SATA cable designed for new system boards and SATA hard drives. The LSATA6 SATA Cable features two latching 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
The latching connectors lock when connected to a supporting (latchable) SATA port, ensuring a snug, and secured data connection every time to prevent accidental disconnects.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
StarTech.com Latching SATA Cable - SATA cable - 15 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Latched
Length
15 cm
Connector
7 pin Serial ATA - receptacle
Connector (Second End)
Red
P/N: 25SATSAS35, 25SATSAS35HD, 35S24M2NGFF, BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F, CFAST2SAT25, HSB225S3R, SATSASBP425, ST521PMINT, USB2SATAIDE, USB3SSATAIDE
Storage Cable Type
SATA cable
Interface Speed
American Wire Gauge (AWG)
26
Latched
Length
15 cm
Red
Connector
RoHS
7NZG StarTech.com 12in Latching SATA Cable In Stock £3.34
7NZG StarTech.com 18in Latching SATA Cable In Stock £3.74
7NZG StarTech.com 24in Latching SATA Cable In Stock £4.50
7NZG StarTech.com 12in Latching SATA to Right Angle SATA Serial ATA Cable In Stock £3.40
7NZG StarTech.com 6in Latching SATA Cable In Stock £3.34
Length: 15cm
Type: SATA
Price Range Ex VAT: 0 - 50
