The HDMIEXTAA6IN HDMI Port Saver Cable is a 6-inch HDMI cable designed to prevent wear and tear on the HDMI port on your computer or A/V device (Blu-Ray player, A/V receiver etc.). The port saver cable features 1 HDMI (male) connector and 1 HDMI (female) connector, which extends the HDMI (female) port from a video card or A/V device away from the device itself, relieving the stress of repeated HDMI plug insertions and removals and transferring the weight of typical HDMI cable connection away from the device port.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
- StarTech.com 6 in HDMI Extension Cable, Short HDMI Cable Male to Female, 4K HDMI Cable Extender, 4K 30Hz UHD HDMI Port Saver M/F, High Speed HDMI 1.4, 10.2Gbps Bandwidth, 30AWG, Black - HDMI Dongle Extender - HDMI cable - 15 cm
- Cable
- HDMI cable
- Length
- 15 cm
- Black
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - female
- Limited lifetime warranty
- Designed For
- P/N: CDP2HDMM2MB, DP2HDMM2MB, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50, MDP2HDMM2MB
- Cable Type
- HDMI cable
- Length
- 15 cm
- Black
- Connector
- 19 pin HDMI Type A - male
- 19 pin HDMI Type A - female
- RoHS
- Limited warranty - lifetime
- Designed For
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.29 |
StarTech.com 3 ft Standard HDMI Cable for Panel Mount - F/M | In Stock | £9.49 |
StarTech.com 6in High Speed HDMI 2.0 Port Saver Cable with 4K 60Hz - Grip | In Stock | £11.52 |
