StarTech.com 6in High Speed HDMI Port Saver Cable M/F - Ultra HD 4k x 2k HDMI Cable
Quicklinx: 76S2WS00 Mfr#: HDMIEXTAA6IN
Type: HDMI
Length: 15cm
14 in stock
£10.85 ex VAT
£13.02 inc VAT
The HDMIEXTAA6IN HDMI Port Saver Cable is a 6-inch HDMI cable designed to prevent wear and tear on the HDMI port on your computer or A/V device (Blu-Ray player, A/V receiver etc.). The port saver cable features 1 HDMI (male) connector and 1 HDMI (female) connector, which extends the HDMI (female) port from a video card or A/V device away from the device itself, relieving the stress of repeated HDMI plug insertions and removals and transferring the weight of typical HDMI cable connection away from the device port.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com 6in High Speed HDMI Port Saver Cable M/F - Ultra HD 4k x 2k HDMI Cable - HDMI Port Saver 6-inch (HDMIEXTAA6IN) - HDMI cable - 15 cm
Cable
HDMI cable
Length
15 cm
Connector
HDMI - male
Connector (Second End)
HDMI - female
P/N: CDP2HDMM2MB, DP2HDMM2MB, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50, MDP2HDMM2MB
Cable Type
HDMI cable
Length
15 cm
Connector
19 pin HDMI Type A - male
19 pin HDMI Type A - female
RoHS
Limited warranty - lifetime
76S2 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £8.48
76S2 StarTech.com 3 ft Standard HDMI Cable for Panel Mount - F/M In Stock £8.72
76S2 StarTech.com 6in High Speed HDMI Port Saver Cable M/F - Ultra HD 4k x 2k HDMI Cable In Stock £10.85
76S2 StarTech.com 6in High Speed HDMI 2.0 Port Saver Cable with 4K 60Hz - Grip In Stock £11.97
Type: HDMI
Length: 15cm
Stock Status: In stock
