StarTech.com 6in DVI-D Dual Link Digital Port Saver Extension Cable M/F
Quicklinx: 7WYWWS00 Mfr#: DVIDEXTAA6IN
Length: 15.2cm
£9.57 ex VAT
£11.48 inc VAT
Extend a DVI-D port by 6in, to prevent unnecessary strain on the port. The DVIDEXTAA6IN 6-inch DVI-D Port Saver Cable/coupler avoids expensive repairs to a computer or display. It does this by extending the port by 6in, thereby eliminating the weight and stress that would typically be placed on the port by a DVI cable. This is especially useful in an environment where cables are unplugged and re-inserted frequently.
The 6in DVI-D cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec, and is fully compliant with DVI DDWG standards.
StarTech.com 6in DVI-D Dual Link Digital Port Saver Extension Cable M/F - DVI-D Male to Female Extension Cable - 6 inch - 2560x1600 (DVIDEXTAA6IN) - DVI extension cable - 15.2 cm
DVI extension cable - dual link
Length
15.2 cm
Connector
DVI-D - male
Connector (Second End)
DVI-D - female
RoHS
P/N: CDP2DVIMM2MB, DP2DVI2MM3, DP2DVI2MM6, DP2DVIMM10, DP2DVIMM6, DP2DVIMM6BS, DP2DVIMM6X10, DVIDDMM10, DVIDDMM6, DVIDSMM10, DVIMM6, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6
DVI extension cable
Shielding Material
American Wire Gauge (AWG)
28
TMDS Links
Dual link
Length
15.2 cm
Connector
24+1 pin digital DVI - male
24+1 pin digital DVI - female
RoHS
Length: 15.2cm
