The DP2MDPMF6IN DisplayPort to Mini DisplayPort Adapter turns a mini DisplayPort (male) connector into a regular DisplayPort (male) connector, making it easy to connect a mini DisplayPort-equipped monitor to a laptop that only provides a standard DisplayPort output (e.g. Apple, Toshiba etc.).
- StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F - DP Male to Mini DP Female - Black (DP2MDPMF6IN) - DisplayPort adapter - 15.2 cm
- Molded
- Length
- 15.2 cm
- Connector
- DisplayPort - male
- Connector (Second End)
- Mini DisplayPort - female
- RoHS
- Limited lifetime warranty
- Designed For
- P/N: SV231DPU, SV231DPUA
- Shielding Material
- PVC
- American Wire Gauge (AWG)
- 32
- Molded
- Length
- 15.2 cm
- Connector
- 20 pin DisplayPort - male
- DisplayPort 1.2, RoHS
- Designed For
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £15.63 |
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £15.21 |
StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F | In Stock | £11.14 |
StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M | In Stock | £33.86 |
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £22.41 |
StarTech.com 6 ft DisplayPort Video Extension Cable - M/F | In Stock | £22.03 |
StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £7.46 |
StarTech.com Mini DisplayPort to DVI Video Adapter Converter | In Stock | £10.55 |
StarTech.com Mini DisplayPort to VGA Video Adapter Converter | In Stock | £19.21 |
StarTech.com Mini DisplayPort to HDMI Video Adapter Converter | In Stock | £9.92 |
StarTech.com 3ft DisplayPort Panel Mount Cable - F/M | In Stock | £11.01 |
StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F | In Stock | £5.61 |
