Product
StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F
Quicklinx: 76LPWS00 Mfr#: DP2MDPMF6IN
Type: DisplayPort
Length: 15.2cm
More than 50 in stock
£5.56 ex VAT
£6.67 inc VAT
Standard delivery Delivered within 3-5 working days
The DP2MDPMF6IN DisplayPort to Mini DisplayPort Adapter turns a mini DisplayPort (male) connector into a regular DisplayPort (male) connector, making it easy to connect a mini DisplayPort-equipped monitor to a laptop that only provides a standard DisplayPort output (e.g. Apple, Toshiba etc.).
StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - DisplayPort adapter - 15.2 cm
DisplayPort adapter
Molded
Length
15.2 cm
Connector
DisplayPort - male
Connector (Second End)
Mini DisplayPort - female
RoHS
P/N: SV231DPUA
DisplayPort adapter
Shielding Material
PVC
American Wire Gauge (AWG)
32
Molded
Length
15.2 cm
Connector
20 pin DisplayPort - male
DisplayPort 1.2, RoHS
P/N: SV231DPU, SV231DPUA, SV431DPUA
76LP StarTech.com 6 ft DisplayPort Video Extension Cable - M/F In Stock £22.18
76LP StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £7.40
76LP StarTech.com Mini DisplayPort to DVI Video Adapter Converter In Stock £10.46
76LP StarTech.com Mini DisplayPort to VGA Video Adapter Converter In Stock £19.01
76LP StarTech.com Mini DisplayPort to HDMI Video Adapter Converter In Stock £9.84
76LP StarTech.com 3ft DisplayPort Panel Mount Cable - F/M In Stock £11.08
76LP StarTech.com 3 ft Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k In Stock £9.97
76LP StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F In Stock £5.56
Type: DisplayPort
Length: 15.2cm
Price Range Ex VAT: 0 - 50
