The DP2MDPMF6IN DisplayPort to Mini DisplayPort Adapter turns a mini DisplayPort (male) connector into a regular DisplayPort (male) connector, making it easy to connect a mini DisplayPort-equipped monitor to a laptop that only provides a standard DisplayPort output (e.g. Apple, Toshiba etc.).
- StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter (DP2MDPMF6IN) - DisplayPort adapter - 15.2 cm
- Molded
- Length
- 15.2 cm
- Connector
- DisplayPort - male
- Connector (Second End)
- Mini DisplayPort - female
- RoHS
- Limited lifetime warranty
- Designed For
- P/N: SV231DPU, SV231DPUA
- Shielding Material
- PVC
- American Wire Gauge (AWG)
- 32
- Molded
- Length
- 15.2 cm
- Connector
- 20 pin DisplayPort - male
- DisplayPort 1.2, RoHS
- Designed For
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £11.58 |
StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F | In Stock | £10.50 |
StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M | In Stock | £21.26 |
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £20.51 |
StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £9.00 |
StarTech.com Mini DisplayPort to DVI Video Adapter Converter | In Stock | £9.55 |
StarTech.com Mini DisplayPort to HDMI Video Adapter Converter | In Stock | £10.66 |
StarTech.com 3ft DisplayPort Panel Mount Cable - F/M | In Stock | £14.45 |
StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F | In Stock | £8.26 |
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F | In Stock | £8.18 |
StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F | In Stock | £8.20 |
StarTech.com 2m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £10.55 |
StarTech.com 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £3.73 |
StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £11.66 |
