StarTech.com 6in DisplayPort Port Saver Cable – M/F
Quicklinx: 76LRWS00 Mfr#: DPEXTAA6IN
The DPEXTAA6IN 6-inch DisplayPort Port Saver Cable/coupler avoids expensive repairs to a computer or display. It does this by extending the port by 6in, thereby eliminating the weight and stress that would typically be placed on the port by a DisplayPort cable. This is especially useful in an environment where cables are unplugged and re-inserted frequently.
StarTech.com 6in DisplayPort Port Saver Cable - M/F - port protector - 15 cm
Port protector
Shielded
Latched, molded, HDCP compliant, DPCP compliant
Length
15 cm
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - female
RoHS
P/N: CDP2DP141MB, CDP2DP146B, CDP2DPMM1MB, CDP2DPMM6B, DISPLPORT10L, DISPLPORT15L, DISPLPORT3L, DISPLPORT6L, MDP2DPMM10, MDP2DPMM3, MDP2DPMM6, MDP2DVIMM6BS
Port protector
Shielded
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Gold
Length
15 cm
Connector
20 pin DisplayPort - male
20 pin DisplayPort - female
RoHS
76LR StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £14.12
