Protect a Video card or monitor's VGA interface from damage and wear. The VGAEXTAA6IN 6-inch VGA Port Saver Cable/coupler avoids expensive repairs to a computer or display. It does this by extending the port by 6in, thereby eliminating the weight and stress that would typically be placed on the port by a VGA cable. This is especially useful in an environment where cables are unplugged and re-inserted frequently.
- StarTech.com 6in Coax High Resolution VGA Port Saver Cable - HD15 M/F - VGA extension cable - 15.2 cm
- Length
- 15.2 cm
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- HD-15 (VGA) - female
- RoHS
- Black
- Limited lifetime warranty
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 15.2 cm
- Black
- Connector
- 15 pin HD D-Sub (HD-15) - male
- 15 pin HD D-Sub (HD-15) - female
- RoHS
