StarTech.com 6in Coax High Resolution VGA Port Saver Cable - HD15 M/F
Quicklinx: 76RFWS00 Mfr#: VGAEXTAA6IN
Protect a Video card or monitor's VGA interface from damage and wear. The VGAEXTAA6IN 6-inch VGA Port Saver Cable/coupler avoids expensive repairs to a computer or display. It does this by extending the port by 6in, thereby eliminating the weight and stress that would typically be placed on the port by a VGA cable. This is especially useful in an environment where cables are unplugged and re-inserted frequently.
StarTech.com 6in Coax High Resolution VGA Port Saver Cable - HD15 M/F - VGA extension cable - 15.2 cm
VGA extension cable
Length
15.2 cm
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - female
RoHS
VGA extension cable
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
15.2 cm
Connector
15 pin HD D-Sub (HD-15) - female
RoHS
