StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter
Quicklinx: 3ZLFWS00 Mfr#: SATAPOWADAP
Length: 0.2m
Type: ATA
More than 50 in stock
£2.98 ex VAT
£3.57 inc VAT
This 6in 4 Pin (LP4) Molex to SATA power adapter cable features one 4 Pin Molex (LP4) male connector and one female SATA power connector, allowing you to power a Serial ATA hard drive from a conventional LP4 connection, eliminating the need to upgrade the computer power supply for compatibility with the SATA hard drive.
StarTech.com 6in 4 Pin LP4 to SATA Power Cable Adapter - LP4 to SATA - 6in LP4 to SATA Cable - 4 pin to SATA power - power cable - 0.2 m
Power cable
Length
0.2 m
Connector
15 pin Serial ATA power - male
Connector (Second End)
4 PIN internal power - male
P/N: BNDTBUSB3142, BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB43SATSASB, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311AC2, PEXUSB311AC3, PEXUSB311EI, PEXUSB312A2, PEXUSB312C2, PEXUSB312EIC, PEXUSB314A2V, PEXUSB3S3GE, PEXUSB3S42, PEXUSB3S7, SATBP125VP
Power cable
Length
0.2 m
Connector
P/N: 25SAT35HDD, 35BAYUSB3S4, ATXPOW250PRO, ATXPOW300PRO, ATXPOW330HS, ATXPOW350DF, ATXPOW350PRO, ATXPOW400DF, ATXPOWER250, ATXPOWER300, ATXPOWER300B, BNDTBUSB3142, BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET25SAT, BRACKET25X2, BRACKET425F, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB2535SATBK, HSB3SATSASBA, HSB43SATSASB, HSB4SATSASBA, PATA2SATA3, PEXUS313AC2V, PEXUSB311A1E, PEXUSB311AC2, PEXUSB311AC3, PEXUSB311EI, PEXUSB312A2, PEXUSB312C2, PEXUSB312EIC, PEXUSB314A2V, PEXUSB3S2EI, PEXUSB3S3GE, PEXUSB3S42, PEXUSB3S7, RMC2300, S32M2NGFFPEX, SAT2MSAT25, SAT32MSATPEX, SATBP125VP
3ZLF StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £2.98
3ZLF StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F In Stock £4.36
3ZLF StarTech.com 12in LP4 to 2x Latching SATA Power Y Cable Splitter Adapter - 4 Pin Molex to Dual SATA In Stock £3.85
3ZLF StarTech.com 12in LP4 to 2x Right Angle Latching SATA Power Y Cable Splitter - 4 Pin Molex to SATA In Stock £3.92
Length: 0.2m
Type: ATA
Price Range Ex VAT: 0 - 50
