StarTech.com 6in 4 Pin Molex to Left Angle SATA Power Cable Adapter
Quicklinx: 8G5MWS00 Mfr#: SATAPOWADPL
Length: 15cm
11 in stock
£3.32 ex VAT
£3.98 inc VAT
Power a SATA hard drive from a conventional LP4 power supply connection. The SATAPOWADPL Molex to 90-degree SATA power adapter features one 4-Pin Molex (LP4) male connector and a left angle, 90-degree SATA power connector (female), which enables you to power a Serial ATA hard drive from a conventional LP4 connection and eliminates the need to upgrade the computer power supply for compatibility with the SATA hard drive.
The 90-degree (left angle) SATA power connector makes it easier to connect a SATA drive that's installed in hard to reach areas or tight spaces, avoiding the strain on both the connector and cable.
StarTech.com 6in 4 Pin LP4 to Left Angle SATA Power Cable Adapter - power adapter - 15 cm
Power adapter
Left-angled connector
Length
15 cm
Connector
15 pin Serial ATA power - male
Connector (Second End)
4 PIN internal power - male
Power adapter
Length
15 cm
Connector
8G5M StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £2.95
8G5M StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter In Stock £3.38
8G5M StarTech.com 6in LP4 to LP4 SATA Power Y Cable Adapter In Stock £3.30
8G5M StarTech.com 6in 4 Pin Molex to Right Angle SATA Power Cable Adapter In Stock £4.11
Length: 15cm
Price Range Ex VAT: 0 - 50
