Just because your motherboard has a 24-pin ATX connector, it doesn't mean you have to pay for an expensive 24-pin ATX power supply. This adapter cable turns your power supply's 20-pin male ATX connector into the 24-pin male ATX connector needed by high-end motherboards. This reliable power adapter is backed by our lifetime warranty.
- Eiminates the need to purchase an expensive power supply with 24-pin power connector to replace your existing 20-pin power supply
- StarTech.com's lifetime warranty
- StarTech.com's adapter cable converts your existing standard 20-pin ATX power supply to work as a 24-pin ATX power supply
- StarTech.com 20 Pin ATX Power Supply to 24 Pin Motherboard Adatper - power connector adaptor - 20 pin ATX to 24 pin ATX - 15.2 cm
- Power connector adaptor
- Length
- 15.2 cm
- Connector
- Power 20 pin ATX - male
- Connector (Second End)
- Power 24 pin ATX - female
- Limited lifetime warranty
- Designed For
- P/N: ATXPOW330HS, ATXPOWER300B, ATXPOW400DF, ATXPOW350PRO, ATXPOW350DF, ATXPOW250PRO, ATXPOWER250, ATXPOWER300
- Length
- 15.2 cm
- Connector
- FCC, RoHS
- Designed For
- P/N: ATXPOW250PRO, ATXPOW330HS, ATXPOW350DF, ATXPOW350PRO, ATXPOW400DF, ATXPOWER250, ATXPOWER300, ATXPOWER300B
Customer reviews
Write a review for the StarTech.com 6in 20 Pin ATX Power Supply to 24 Pin Motherboard Adapter here!
description wrong
Reviewed by andy. Review Posted 22/11/2006
The description is wrong. This product converts a 20 pin PSU to a 24pin motherboard.
NOT the other way round.
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
