Product
Brand
StarTech.com 6in 20 Pin ATX Power Supply to 24 Pin Motherboard Adapter
Customer rating: 1.0* (Write a review)
Quicklinx: 3ZM7WS00 Mfr#: ATX2024MF
Just because your motherboard has a 24-pin ATX connector, it doesn't mean you have to pay for an expensive 24-pin ATX power supply. This adapter cable turns your power supply's 20-pin male ATX connector into the 24-pin male ATX connector needed by high-end motherboards. This reliable power adapter is backed by our lifetime warranty.
  • Eiminates the need to purchase an expensive power supply with 24-pin power connector to replace your existing 20-pin power supply
  • StarTech.com's lifetime warranty
  • StarTech.com's adapter cable converts your existing standard 20-pin ATX power supply to work as a 24-pin ATX power supply
StarTech.com 20 Pin ATX Power Supply to 24 Pin Motherboard Adatper - power connector adaptor - 15.2 cm
Power connector adaptor
Length
15.2 cm
Connector
Power 20 pin ATX - male
Connector (Second End)
Power 24 pin ATX - female
P/N: ATXPOW330HS, ATXPOWER300B, ATXPOW400DF, ATXPOW350PRO, ATXPOW350DF, ATXPOW250PRO, ATXPOWER250, ATXPOWER300
Length
15.2 cm
Connector
FCC, RoHS
P/N: ATXPOW250PRO, ATXPOW330HS, ATXPOW350DF, ATXPOW350PRO, ATXPOW400DF, ATXPOWER250, ATXPOWER300, ATXPOWER300B
Customer reviews
Write a review for the StarTech.com 6in 20 Pin ATX Power Supply to 24 Pin Motherboard Adapter here!
description wrong
Reviewed by andy. Review Posted 22/11/2006
The description is wrong. This product converts a 20 pin PSU to a 24pin motherboard.
NOT the other way round.
  • Overall 1*
  • Ease of use 1*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
