StarTech.com 6ft USB-C to DisplayPort Cable
Quicklinx: C53CWS00 Mfr#: CDP2DPMM6B
Length: 1.8m
Select:
More than 50 in stock
£21.04 ex VAT
£25.24 inc VAT
This USB-C to DisplayPort adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your DisplayPort monitor or projector, at up to 6 ft. away.
The adapter works with USB-C devices that support DP alt mode, such as the MacBook, ChromeBook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 6 ft. (1.8 m) in length, this adapter cable delivers a compact connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. For shorter installations, StarTech.com also offers a 6 ft. (1m) USB-C to DP cable (CDP2DPMM1MB), enabling you to choose the right cable length for your custom installation needs.
The adapter cable is easy to connect, through the versatility and convenience of the USB Type-C port on your desktop, laptop or tablet. USB-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always connect, saving you the frustration of trying to insert it correctly when you're trying to dock your computer to your workstation or office hot desk.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display.
Plus, the adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other work environments.
Your USB-C equipped device must support video (DP alt mode) to work with this adapter.
StarTech.com 6ft/1.8m USB C to DisplayPort 1.2 Cable 4K 60Hz - USB Type-C to DP Video Adapter Monitor Cable HBR2 - TB3 Compatible - Black - external video adapter - STM32F072CBU6 - black
External video adapter
Bus Type
USB-C
Graphics Engine
STM32F072CBU6
Max Resolution
3840 x 2160
DisplayPort (male connector)
Length
1.8 m
Enclosure Colour
3-year warranty
P/N: TB33A1C, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
Bus Type
USB-C
Graphics Engine
STM32F072CBU6
Max Resolution
3840 x 2160 at 60 Hz
HD/4k Ready, 7.1 channel surround sound ready, DisplayPort Alternate Mode, Thunderbolt 3 compatible
FCC, RoHS
Length
1.8 m
51 g
Enclosure Colour
Limited warranty - 3 years
20 - 70%
C53C StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £27.63
C53C StarTech.com 6ft USB-C to DisplayPort Cable In Stock £21.04
C53C StarTech.com USB-C to DisplayPort MST Hub - 2-Port In Stock £56.66
C53C StarTech.com USB-C to HDMI Adapter - 4K60Hz In Stock £20.98
C53C StarTech.com USB-C to DisplayPort Adapter In Stock £17.90
C53C StarTech.com USB-C to HDMI - Power Delivery In Stock £25.86
C53C StarTech.com USB-C to DP MST Hub - 3-Port In Stock £82.88
Length: 1.8m
Price Range Ex VAT: 0 - 50
