StarTech.com 6ft Toslink SPDIF Audio Cable
Quicklinx: BSHJWS00 Mfr#: THINTOSMIN6
Length: 1.8m
Select:
15 in stock
£4.21 ex VAT
£5.05 inc VAT
This 6ft Toslink to Miniplug digital audio cable offers an easy way to connect your Toslink devices to Miniplug devices, allowing you to get the most out of your digital audio gear, even at extreme volumes.
Thinner than the regular audio cables, the cable provides one Toslink male connector and one mini-optical male connector and features flexible PVC jacket construction that lets you bend the cable into any position you need without damaging the cable or losing any sound quality.
StarTech.com 6 ft. (1.8 m) Toslink to Mini Toslink Cable - Toslink to Mini SPDIF - Audio Cable - Black - Digital Optical Cable (THINTOSMIN6) - digital audio cable (optical) - 1.8 m
Cable
Digital audio cable (optical) - SPDIF
Fibre optic
Length
1.8 m
Connector
TOSLINK - male
Connector (Second End)
Mini TOSLINK - male
P/N: ICUSBAUDIO2D, PEXSOUND7CH
Cable Type
Interface Supported
SPDIF
Fibre optic
Jacket Material
PVC
Length
1.8 m
Connector
TOSLINK - male
Mini TOSLINK - male
Limited warranty - lifetime
Length: 1.8m
Stock Status: In stock
