This 6ft Toslink to Miniplug digital audio cable offers an easy way to connect your Toslink devices to Miniplug devices, allowing you to get the most out of your digital audio gear, even at extreme volumes.
Thinner than the regular audio cables, the cable provides one Toslink male connector and one mini-optical male connector and features flexible PVC jacket construction that lets you bend the cable into any position you need without damaging the cable or losing any sound quality.
- StarTech.com 6 ft. (1.8 m) Toslink to Mini Toslink Cable - Toslink to Mini SPDIF - Audio Cable - Black - Digital Optical Cable (THINTOSMIN6) - digital audio cable (optical) - SPDIF - 1.8 m
- Cable
- Digital audio cable (optical) - SPDIF
- Technology
- Fibre optic
- Length
- 1.8 m
- Connector
- TOSLINK - male
- Connector (Second End)
- Mini TOSLINK - male
- Limited lifetime warranty
- Designed For
- P/N: ICUSBAUDIO2D, PEXSOUND7CH
- Cable Type
- Interface Supported
- SPDIF
- Technology
- Fibre optic
- Jacket Material
- PVC
- Length
- 1.8 m
- Connector
- TOSLINK - male
- Limited warranty - lifetime
- Designed For
