StarTech.com 6ft Straight Through Serial Cable - DB9 M/F
Quicklinx: 3ZN1WS00 Mfr#: MXT100
Length: 1.8m
Type: Serial
More than 50 in stock
£3.51 ex VAT
£4.21 inc VAT
Extend your EGA monitor cable or mouse cable by 6ft. The MXT100 Straight Through Serial Cable features one DB9 male connector and one DB9 female connector, providing a high quality serial mouse or EGA monitor extension.
StarTech.com 6 ft Straight Through Serial Cable - DB9 M/F - serial cable - 1.8 m
Serial cable
Length
1.8 m
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
9 pin D-Sub (DB-9) - female
P/N: PEX1S553, PEX2S553LP, PEX2S553, PEX1S553LP, PCI2S232485I, PEX16S952LP, PCI8S950LP, PEX1S552LP, PEX2S552LP, PEX4S952LP, PEX2S552, PEX1S552, SV1115IPEXGB, PEX4S950, PEX4S550, EC4S950, CB1S485, CB2S950, PEX2S950, SV1115IPEXT, CB1PECP, EC2S950, EC1S950, CB4S950, PCI2S950DV, PCI1S950DV, PCI1PECPDV
Serial cable
Length
1.8 m
Connector
StarTech.com 1 Port 16550 PCI Express Serial Card, 1 Port CardBus PCMCIA Parallel Laptop Adapter Card, 1 Port CardBus PCMCIA RS422 RS485 Serial Laptop Adapter Card, 1 Port ExpressCard RS232 Serial Adapter Card with 16950 UART, 1 Port ISA RS232 Serial Adapter Card with 16550 UART, 1 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART, 1 port Native PCI Express RS232 Serial Adapter Card with 16550 UART, 1 Port PCI Dual Voltage Parallel Adapter Card, 1 Port PCI Low Profile RS232 Serial Adapter Card with 16550 UART, 1 Port PCI RS232 Serial Adapter Card w/ 16950 UART - Dual Voltage, 1 Port PCI RS232 Serial Adapter Card with 16550 UART, 1 Port USB PS/2 Server Remote Control IP KVM w/Virtual Media & Serial, 16 Port Low Profile RS232 PCI Express Serial Card - Cable Included, 2 Port 16550 PCI Express Serial Card, 2 Port 16650 PCI-E WHQL Approved Serial Card, 2 Port CardBus RS232 Serial Laptop PC Adapter Card - 16950, 2 Port ExpressCard Serial Adapter Card, 2 Port ISA RS232 Serial Adapter Card with 16550 UART, 2 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART, 2 Port PCI Express RS232 Serial Adapter Card with 16550 UART, 2 Port PCI RS232 Serial Adapter Card w/ 16950 UART - Dual Voltage, 2 Port RS232/422/485 PCI Serial Adapter Card w/ ESD Protection, 2 Serial/1 Parallel Port Dual Voltage WHQL PCI Card, 2S1P PCI Serial Parallel Combo Card with 16550 UART, 4 Port 16950 Serial CardBus Adapter, 4 Port ExpressCard 16C950 Serial Card, 4 Port Low Profile Native RS232 PCI Express Serial Card with 16950 UART, 4 Port PCI Express RS232 Serial Adapter Card with 16950 UART, 4 Port PCI Express Serial Card, 4 Port PCI Express WHQL Approved Serial Card, 8 Port Low Profile RS232 PCI Serial Card with 16950 UART, PCI1S650DV, PCI2S650DV, PCI4S650DV, SV1110IPEXT Server Remote Control KVM Control Over IP
Length: 1.8m
Type: Serial
Price Range Ex VAT: 0 - 50
