StarTech.com 6ft DP Mini DP HDMI to HDMI
Quicklinx: BRVDWS00 Mfr#: DPMDPHD2HD
Length: 2m
33 in stock
£78.42 ex VAT
£94.10 inc VAT
Connect your HDMI, DisplayPort, or Mini DisplayPort laptop to an HDMI display or projector. This unique adapter cable lets you connect almost any laptop or desktop computer to an HDMI display or projector. It supports the HDMI, DisplayPort and Mini DisplayPort output from your computer and video resolutions up to Ultra HD 4K.
This versatile adapter cable is also Thunderbolt compatible, when connected directly to a supporting DisplayPort over a Thunderbolt I/O port.
This adapter cable is ideal for your boardroom's HDMI display or projector. You can reduce clutter and eliminate the need for multiple adapters on your boardroom table by providing a single adapter cable that can support a variety of signals.
The adapter cable supports multiple input signal types, so you'll be able to accommodate a variety of user needs. Employees and guests can plug in their HDMI, DP or mDP laptops and deliver their presentations using your boardroom's HDMI display, without having to carry their own adapters.
This adapter cable ensures you can maintain an astonishing picture quality with four times the resolution of 1080p. The adapter is also backward compatible with lower resolution displays and video sources. With support for high-definition resolutions of 1080p and 720p, you can future-proof your existing setup for 4K video.
The adapter can be powered through the provided Micro-USB cable by connecting the cable from the adapter to a USB port on the user's laptop or to a USB port on the HDMI display. The user can then connect their laptop to either input on the adapter cable and share their presentations.
StarTech.com 2m 6 ft HDMI, DisplayPort or Mini DisplayPort to HDMI Converter Cable - HDMI, DP or Mini DP to HDMI Adapter Cable (DPMDPHD2HD) - video adapter - DisplayPort / HDMI - 2 m
Cable
Video adapter - DisplayPort / HDMI
Length
2 m
Connectors
HDMI - male , DisplayPort - male , Mini DisplayPort - male
Connectors (Second End)
HDMI - male , Micro-USB Type B (power only) - female
Thunderbolt
4K support
Cable Type
Video adapter 4K support
Interface Supported
DisplayPort / HDMI
Thunderbolt
Length
2 m
Connectors
19 pin HDMI Type A - male , 20 pin DisplayPort - male , Mini DisplayPort - male
19 pin HDMI Type A - male , 5 pin Micro-USB Type B (power only) - female
Length: 2m
Price Range Ex VAT: 50 - 100
