This 6ft upward-angle VGA cable is designed to support the highest resolutions and highest video quality possible through VGA while fitting perfectly in tight connection spaces. The cable features one standard VGA connector (HD15) and one VGA connector (HD15) that is situated on an upward angle relative to the shaft of the cable, requiring only 32.4mm of space at the connection point.
Suited for high resolution VGA applications (1280x1024 and above), this high quality coaxial VGA cable eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection using ferrite cores near the connector ends.
- StarTech.com Coax High Resolution 90° Upward Angled VGA Monitor Cable - VGA cable - 1.8 m
- VGA cable
- 90° connector, ferrite bead
- Length
- 1.8 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- RoHS
- Black
- Limited lifetime warranty
- Designed For
- P/N: HDMIPLATE, VGAPLATE
- VGA cable
- American Wire Gauge (AWG)
- 28
- Length
- 1.8 m
- Black
- Connector
- 15 pin HD D-Sub (HD-15) - male
- RoHS
- Designed For
StarTech.com DVI to VGA Cable Adapter - M/F | In Stock | £5.42 |
StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F | In Stock | £7.06 |
StarTech.com Right Angle VGA to VGA Cable Adapter Type 2 - M/F | In Stock | £7.03 |
