StarTech.com 6ft Blue Cat5e UTP Patch Cable
Quicklinx: 76SSWS00 Mfr#: M45PATCH6BL
Length: 1.8m
Colour: Blue
More than 50 in stock
£2.76 ex VAT
£3.31 inc VAT
Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The M45PAT6BL Cat5e Patch Cable (6 ft) meets or exceeds all Cat 5e specifications to ensure reliable Ethernet network connections, and features a durable blue PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat5e patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat5e Patch Cord delivers reliable performance.
  • 100% copper - a better value
    StarTech.com Cat5e cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a "cheaper" cable, based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value and performance for your network cable investment.
  • 24 AWG wire
    This Cat 5e cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, these cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
  • 50-micron gold connectors
    This RJ45 patch cable offers high quality connectors comprised of 50-micron gold, to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
StarTech.com Cat5e Ethernet Cable - 6 ft - Blue - Patch Cable - Molded Cat5e Cable - Short Network Cable - Ethernet Cord - Cat 5e Cable - 6ft (M45PATCH6BL) - patch cable - 1.8 m - blue
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded
Length
1.8 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
P/N: BR4100DC, DKT30CHVGPD, EOC1110K, EOC1110R, MCM110SC2, MCM110SC2EU, MCM110SC2GB, MCM110ST, MCM110ST2, MCM110ST2EU, MCM110ST2GB, MCMGBSC055, PEX100S, ROLLOVER, ST1000SPEX2, ST1000SPEX2L, ST1000SPEXD4, ST1000SPEXI, ST100SLP, ST5GPEXNB, SV565USAGB, USB2106S, USB31000NDS, USB31000S, USB31000SW
Network Cable Type
Wiring Scheme
T568B
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Molded
Length
1.8 m
Blue
Connector
RJ-45 - male
RJ-45 - male
P/N: BR4100DC, DKT30CHVGPD, EOC1110K, EOC1110R, MCM110SC2, MCM110SC2EU, MCM110SC2GB, MCM110ST, MCM110ST2, MCM110ST2EU, MCM110ST2GB, MCMGBSC055, PEX100S, ROLLOVER, ST1000SPEX2, ST1000SPEX2L, ST1000SPEXD4, ST1000SPEXI, ST100S, ST100SLP, ST5GPEXNB, SV565USAGB, USB2106S, USB31000NDS, USB31000S, USB31000SW
76SS StarTech.com 3 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable In Stock £2.62
76SS StarTech.com 10ft Blue Cat5 UTP Patch Cable In Stock £3.32
Length: 1.8m
Colour: Blue
Price Range Ex VAT: 0 - 50
