StarTech.com 6ft 4-in-1 USB DisplayPort KVM Switch Cable with Audio & Microphone
Quicklinx: 76RKWS00 Mfr#: DP4N1USB6
37 in stock
£17.19 ex VAT
£20.62 inc VAT
High Definition video, USB, and audio all in one cable.
This 6-foot 4-in-1 DisplayPort/USB KVM switch cable integrates DisplayPort video quality with USB mouse and keyboard, 3.5mm audio out and microphone connections into a single compact cable.
This convenient 4-in-1 KVM cable is a cost-effective solution that's suitable for use with any DisplayPort supported USB KVM switch, allowing you to share display and USB peripherals between multiple computers configured for high definition output.
This DisplayPort, USB, and Audio KVM cable provides guaranteed performance for dependable operation.
StarTech.com 4-in-1 USB DisplayPort KVM Switch Cable w/ Audio & Microphone - video / USB / audio cable - 1.8 m
Video / USB / audio cable
Molded, colour-coded connectors
Length
1.8 m
Connectors
20 pin DisplayPort - male , 4 pin USB Type A - male , 2 x mini-phone stereo 3.5 mm - male
Connectors (Second End)
20 pin DisplayPort - male , 4 pin USB Type B - male , 2 x mini-phone stereo 3.5 mm - male
P/N: SV231DPU, SV231DPUA
Plated Connector
Gold
Length
1.8 m
Connectors
RoHS
76RK StarTech.com 6 ft 4-in-1 USB DVI KVM Cable with Audio and Microphone In Stock £14.08
76RK StarTech.com 10 ft 4-in-1 USB DVI KVM Cable with Audio and Microphone In Stock £18.53
76RK StarTech.com 6 ft DisplayPort Video Extension Cable - M/F In Stock £22.42
76RK StarTech.com 6ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone In Stock £16.27
76RK StarTech.com 10ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone In Stock £19.26
76RK StarTech.com 15ft 4-in-1 USB Dual Link DVI-D KVM Switch Cable with Audio & Microphone In Stock £28.25
76RK StarTech.com 3ft DisplayPort Panel Mount Cable - F/M In Stock £11.16
76RK StarTech.com 4 Port USB DisplayPort KVM Switch with Audio In Stock £192.66
76RK StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio In Stock £154.07
76RK StarTech.com 6ft 4-in-1 USB DisplayPort KVM Switch Cable with Audio & Microphone In Stock £17.19
Price Range Ex VAT: 0 - 50
