StarTech.com 6ft (2m) Thunderbolt Cable
Quicklinx: HFNSWS00 Mfr#: A40G2MB-TB4-CABLE
Length: 2m
£83.57 ex VAT
£100.28 inc VAT
The 6.6ft (2m) Active Thunderbolt 4 cable enables full Thunderbolt 4 capabilities and outperforms passive cables beyond 3.3ft (1m) length. An active integrated chipset minimizes signal degradation for consistent 40Gbps output at distances of up to 6.6ft (2m), while passive cables deliver limited performance beyond 3.3ft (1m) due to signal loss.
  • 40 Gbps for Thunderbolt 4 / 3 Devices
    This Active Thunderbolt 4 cable supports data transfer rates of 40 Gbps, when connected to a Thunderbolt 4, Thunderbolt 3, or USB4-compatible source and device. It is capable of transferring data four times faster than standard USB 3.2 Gen 2 (10 Gbps) cables. USB Power Delivery 3.0
  • USB-C Compatible
    The Thunderbolt 4 cable is compatible with all USB Type-C devices and can be used to charge and sync mobile devices. In addition, this cable can be used to connect and power USB-C laptops, such as MacBook and Chromebook ; and USB-C peripherals such as portable hard drives and docking stations.
  • Full-8K Video
    The cable supports full-8K 60Hz video and DisplayPort 1.4a, and is compatible with Display Stream Compression (DSC). Use it to connect a docking station to laptop, or a laptop to a display.
  • Thunderbolt Networking
    The cable can be used to daisy chain up to 6 Thunderbolt 4-enabled devices, such as laptops for peer-to-peer 10GbE networking. In addition, connect two Thunderbolt 4 laptops to transfer/migrate data.
StarTech.com 6ft (2m) Active Thunderbolt 4 Cable, 40Gbps, 100W PD, 4K/8K, Intel Certified, Compatible w/Thunderbolt 3/USB 3.2/DisplayPort (A40G2MB-TB4-CABLE) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 2 m
USB-C cable
Shielded
Active adapter, USB Power Delivery (100W), 8K60Hz support, 4K60Hz support, up to 40 Gbps data transfer rate, strain relief, DisplayPort 1.4 with DSC
Length
2 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
USB 3.2 Gen 2 / USB4 / Thunderbolt 3 / Thunderbolt 4- / DisplayPort 1.4a
USB-C cable
Shielded
Shielding Material
Aluminum-polyester foil with tinned copper braid
Jacket Material
PVC
American Wire Gauge (AWG)
30/32
Plated Connector
Nickel
Length
2 m
Outside Diameter
4.7 mm
Connector
24 pin USB-C - male
24 pin USB-C - male
USB 3.2 Gen 2 / USB4 / Thunderbolt 3 / Thunderbolt 4- / DisplayPort 1.4a, FCC, RoHS, WEEE, Thunderbolt 4
Shipping Width
22 cm
Shipping Depth
12.8 cm
Shipping Height
1.6 cm
Shipping Weight
89 g
HFNS StarTech.com 1.6ft USB4 Cable, USB-C 40Gbps In Stock £19.39
Length: 2m
