StarTech.com 6ft / 1.8m DisplayPort to DVI Cable - 1920x1200 -DVI Adapter
Quicklinx: FW6WWS00 Mfr#: DP2DVIMM6X10
Length: 1.828m
£195.49 ex VAT
£234.58 inc VAT
DVI Adapter Cable Multi-Monitor Solution Plug & Play Connectivity Multi-Pack. This 10 pack of DisplayPort to DVI cables lets you connect your DP enabled devices to DVI monitors, TVs or projectors from 6 feet (1.8 meters) away, offering a convenient, clutter-free connection. The bulk-pack option provides you with an efficient solution for multiple implementations.
Crystal-Clear Picture Quality
This DP to DVI cable provides high bandwidth video transmissions, supporting monitor resolutions up to 1920x1200 or HDTV resolutions up to 1080p. The adapter cable takes full advantage of your DVI capable display while harnessing the video capabilities built into your DisplayPort connection to deliver every detail in stunning high-definition.
Simplified Installation
At 6 ft. (1.8 m) in length, this DVI converter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. As well, the cable is easy to use, and requires no additional software or drivers, supporting a true plug-and-play set up.
Works with Your Existing DVI Displays
This DisplayPort (male) to DVI (male) cable makes your DP computer fully compatible with existing DVI monitors or displays in your home or around the office. You can use the cable to either connect to a DVI display or add an additional monitor to your workstation, helping to boost your productivity.
DP2DVIMM6X10 is backed by a StarTech.com 3-year warranty and free lifetime technical support.
Note: This is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
  • Crystal-clear picture quality
  • Simplified installation
  • Works with your existing DVI displays
StarTech.com 10-Pack 6ft DisplayPort to DVI Cable, DisplayPort 1.2 to DVI-D Video Adapter Cable, 1080p, Passive DP++ to DVI Monitor Converter Cable, DP to DVI Digital Display, Male to Male - Passive DP 1.2 to DVI (DP2DVIMM6X10) - video adapter cable - DisplayPort to DVI-D - 1.828 m
Video adapter cable
Packaged Quantity
10 (specifications are for single item)
Passive cable, 1080p support, maximum resolution 1920x1200 at 60Hz
Length
1.828 m
Connector
20 pin DisplayPort - male
Connector (Second End)
24+1 pin digital DVI - male
DisplayPort++
3-year warranty
Packaged Quantity
Video adapter cable
Shielding Material
PVC
Plated Connector
Nickel
Length
1.828 m
3.8 cm
1.5 cm
150 g
Connector
DisplayPort++, FCC, RoHS, REACH
Shipping Width
60 cm
Shipping Depth
45 cm
3-year warranty
FW6W StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £9.78
FW6W StarTech.com 6in DVI-D Dual Link Digital Port Saver Extension Cable M/F In Stock £9.57
FW6W StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £10.14
Length: 1.828m
