StarTech.com 65x60x45mm Socket 7/370 CPU Cooler Fan with Heatsink & TX3 connector
Quicklinx: 4048WS00 Mfr#: FAN370PRO
Type: Heatsink
22 in stock
£6.34 ex VAT
£7.60 inc VAT
The StarTech.com Socket 7/370 CPU Cooler with its 2cm fan cooling fan is a combination heatsink and fan designed to cool high-performance CPUs. It sports an extra-large heatsink with enough cooling capacity for Pentium III and Celeron CPUs up to 1.4 GHz. A quiet running 6x2 cm brushless ball bearing DC motor coupled with a high-efficiency blade design is capable of moving 21.46 CFM (cubic feet per minute) of air. Power is supplied to the fan using a 3-lead TX3 connector that plugs into the motherboard and allows the system to monitor fan speed and operating status. For LP4 connection, add optional accessory CPUFANADAPT.
StarTech.com 65x60x45mm Socket 7/370 CPU Cooler Fan w/ Heatsink & TX3 connector (FAN370PRO) processor cooler
Processor cooler
Compatibility
Socket 370, Socket 7
Fan Diameter
60 mm
Fan Height
20 mm
Rotation Speed
4000 rpm
Air Flow
20.2 cfm
Noise Level
31 dBA
Power Connector
3-pin plug
Ball bearing
1-year warranty
Processor cooler
Heatsink & Fan
Compatible With
Heatsink Dimensions
66 mm x 60 mm x 25 mm
Thermal Resistance
0.64 °C/W
Fan Diameter
60 mm
Fan Height
20 mm
Rotation Speed
4000 rpm
Air Flow
20.2 cfm
Noise Level
31 dBA
Power Connector
3-pin plug
Ball bearing
Limited warranty - 1 year
4048 StarTech.com 12in Fan Adapter - TX3 to 2x LP4 Power Y Splitter Cable In Stock £2.76
4048 StarTech.com 1.5g Metal Oxide Thermal CPU Paste Compound Tube for Heatsink In Stock £3.78
Type: Heatsink
Price Range Ex VAT: 0 - 50
