StarTech.com 60x25mm High Air Flow Dual Ball Bearing Computer Case Fan with TX3
Quicklinx: 4040WS00 Mfr#: FAN6X25TX3H
Type: Case Fan
35 in stock
£6.60 ex VAT
£7.92 inc VAT
This 6cm x 2.5cm (5000 RPM) Computer Case Fan helps prevent computer systems from overheating, thereby increasing efficiency and stability.
The fan features a TX3 connection and a built-in tachometer that sends RPM signals to your motherboard - a high-performance solution that can help avoid overheating and system failure.
StarTech.com 60x25mm High Air Flow Dual Ball Bearing Computer Case Fan w/ TX3 - 3 pin case Fan - TX3 Fan - 60mm Fan (FAN6X25TX3H) system fan kit
System fan kit
Fan Diameter
60 mm
6 cm x 6 cm x 2.5 cm
25 g
Fan speed monitoring
1-year warranty
P/N: RMC4450
System fan kit
6 cm
6 cm
2.5 cm
25 g
Heatsink & Fan
Fan Diameter
60 mm
Limited warranty - replacement - 1 year , Parts and labour
StarTech.com 4U Black Steel Rack Mount Server Case with 450W P4 Power Supply
4040 StarTech.com 60x20mm Replacement Ball Bearing Computer Case Fan with TX3 Connector In Stock £8.86
4040 StarTech.com 60x25mm High Air Flow Dual Ball Bearing Computer Case Fan with TX3 In Stock £6.60
4040 StarTech.com 60x10mm Replacement Ball Bearing Computer Case Fan with TX3 Connector In Stock £5.25
Type: Case Fan
Price Range Ex VAT: 0 - 50
