Connect your VGA monitor with the highest quality connection available. This 60-foot High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male-to-male coaxial VGA cable eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial cables, while providing superior EMI interference protection by using ferrite cores near the connector ends.
- StarTech.com 60 ft Coax High Resolution Monitor VGA Cable - HD15 M/M - VGA cable - 18.3 m
- VGA cable
- Technology
- Triple shielded twisted pair coaxial
- Ferrite bead
- Length
- 18.3 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- NEC-CMG
- Black
- Limited lifetime warranty
- VGA cable
- Technology
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Ferrite bead
- Length
- 18.3 m
- Black
- Connector
- 15 pin HD D-Sub (HD-15) - male
- NEC-CMG
