StarTech.com 6-Slot TB3 SD Card Reader
Quicklinx: F2K5WS00 Mfr#: 6SD4FCRTB3C
£125.89 ex VAT
£151.06 inc VAT
This Thunderbolt 3 SD card reader and writer lets you access up to six SD cards at the same time from your laptop. It's perfect for when you are working offsite on assignment.
The reader is also ideal for creative professionals such as photographers and videographers who work with 4K and 3D content.
  • Portable design
    Access your photos and videos anywhere you go. The portable SD card reader has a sleek, compact design for maximum convenience. The integrated Thunderbolt 3 cable lets you quickly access your data without having to stop and find a cable. Plus, the reader is powered through the Thunderbolt 3 port on your laptop. There's no need to carry a separate power adapter.
  • Multi-card reader supports all SD card types
    The 6-slot Thunderbolt 3 card reader supports all SD cards: SD (Secure Digital), SDHC (Secure Digital High Capacity) and SDXC (Secure Digital Extended Capacity). Each slot is UHS-II enabled so that you can access data at up to UHS-II speeds. The reader also supports Micro SD cards when connected through an adapter.
  • Thunderbolt 3 support
    The reader transfers files between a Thunderbolt 3 computer or tablet and SD cards. You can connect it at the end of a daisy chain and expect all of the security and benefits that you would from any Thunderbolt 3 product.
StarTech.com 6-Slot Thunderbolt 3 SD Card Reader - Portable - SD / SDHC / SDXC - SD 4.0 UHS-II - TAA Compliant - Multi-Card Reader (6SD4FCRTB3C) - card reader - USB 3.1
Card reader - external
Supported Memory Cards
MultiMediaCard, SD Memory Card, SDHC UHS-II Memory Card, SDXC UHS-II Memory Card
Host Interface
USB 3.1
Black, silver
Integrated USB cable, LED indicator
Host Interface
USB 3.1
Black, silver
8.2 cm
13.5 cm
1.9 cm
90 g
Memory Card
(max)
Additional Ports
1 x USB charge port
Required Ports
1 x 24 pin USB-C
FCC, RoHS, WEEE, RCM
Shipping Weight
100 g
F2K5 StarTech.com 3.5in Drive Bay IDE to Single CF SSD Adapter Card Reader In Stock £18.42
F2K5 StarTech.com USB 3.0 Multi Media Flash Memory Card Reader In Stock £22.40
F2K5 StarTech.com USB 3.0 External Flash Multi Media Memory Card Reader - SDHC MicroSD In Stock £11.68
F2K5 StarTech.com 3.5in Front Bay 22-in-1 USB 2.0 Internal Multi Media Memory Card Reader - Black In Stock £12.11
F2K5 StarTech.com Micro SD to Micro USB / USB OTG Adapter Card Reader For Android Devices In Stock £5.61
Supported Formats: MultiMediaCard
Supported Formats: SD Memory Card
Supported Formats: SDHC UHS-II Memory Card
Supported Formats: SDXC UHS-II Memory Card
Interface: USB 3.1
