StarTech.com 6 Port Industrial Gigabit Ethernet Switch, 4 PoE+ Ports and Voltage Regulation
Quicklinx: 98G0WS00 Mfr#: IES61002POE
Type: Gigabit Ethernet
Ports: 6
Data Transfer Rate: 1Gbps
Managed: No
POE: PoE+
£225.18 ex VAT
£270.21 inc VAT
Connect Gigabit Ethernet data and power to 4 PoE-enabled devices, with 2 additional GbE ports - DIN/Wall Mountable. The IES61002POE 6-Port Industrial PoE+ switch lets you connect Gigabit Ethernet data and power to four PoE-enabled devices, with two additional GbE ports.
Fully compliant with IEEE 802.3at / 802.3af, the industrial Ethernet switch offers up to 30 Watts output per port, through the four PoE+ / PSE ports, while all six shielded RJ45 ports support auto-negotiation of speed and duplex for 10/100/1000Mbps Ethernet networks.
Providing seamless power failover in the event of power dips or failures, the switch features redundant 20-57V DC (nominal 24/48V DC) terminal block power inputs. The switch also features an internal DC-DC converter, which provides the PoE injector with high voltage output from a low voltage input (<24V DC). When used with multiple power sources, the switch supports alarm relay contacts, which can be wired to your existing alarm circuit to give you instant notice when a power disruption occurs.
To ensure dependable performance in harsh environments, this power over Ethernet switch features an extended operating temperature range (-40°C to 75°C), a rugged IP-30 rated case design and includes both DIN-Rail and wall-mount brackets for flexible installation options.
StarTech.com 6 Port Unmanaged Industrial Gigabit Ethernet Switch w/ 4 PoE+ Ports & Voltage Regulation - DIN Rail/Wall Mountable PoE Switch (IES61002POE) - switch - 6 ports - unmanaged
Switch - 6 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
4 x 10/100/1000 (PoE+) + 2 x 10/100/1000
Power Over Ethernet (PoE)
PoE+
Auto-uplink (auto MDI/MDI-X), store and forward, full duplex mode
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
DC 24/48 V
6.3 cm x 10.6 cm x 13.5 cm
840 g
P/N: POEEXT1GAT, POEEXT2GAT
Enclosure Type
DIN rail mountable, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
Status Indicators
Port transmission speed, power, fail, PoE, link/activity
4 x 1000Base-T RJ-45 PoE+ - 30 W , 2 x 1000Base-T RJ-45
Internal power supply
DC 24/48 V
143 Watt
MTBF
296,517 hour(s)
EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, EN 61000-4-5, FCC, EN 61000-6-2, RoHS, EN 61000-4-8, UL 60950-1, EN 61000-6-4, IEC 60068-2-27, IEC 60068-2-32, IEC 60068-2-6, EN 50121-4, IP30
6.3 cm
10.6 cm
13.5 cm
840 g
-40 °C
75 °C
5 - 95% (non-condensing)
Min Storage Temperature
-50 °C
Max Storage Temperature
85 °C
98G0 StarTech.com 25 ft Cat 6 Blue Molded RJ45 UTP Gigabit Cat6 Patch Cable In Stock £7.31
98G0 StarTech.com 1000ft Roll Blue Stranded Cat 6 Patch Cable In Stock £242.78
98G0 StarTech.com 5 Port Unmanaged Industrial Gigabit PoE Switch with 4 Power over Ethernet ports In Stock £166.00
98G0 StarTech.com 6 Port Industrial Gigabit Ethernet Switch, 4 PoE+ Ports and Voltage Regulation In Stock £225.18
98G0 StarTech.com 1 Port RS232 Serial Ethernet Device Server - PoE Power Over Ethernet In Stock £102.73
Ports: 6
Managed: No
POE: PoE+
Price Range Ex VAT: 150 - 300
