StarTech.com 6 ft USB Y Cable for External Hard Drive - USB A to mini B
Quicklinx: 76QVWS00 Mfr#: USB2HABMY6
Length: 1.8m
Select:
More than 50 in stock
£3.88 ex VAT
£4.65 inc VAT
Connect and power your external mini-USB equipped hard drive through two standard USB ports on your computer. The USB2HABMY6 6 ft USB-A to Mini-B Y cable features two USB-A male connectors and a single USB Mini-B male connector - an ideal solution for providing additional power to your mini-USB external hard drive by connecting to two USB-A ports on your computer or laptop.
Especially valuable in situations where a single USB 2.0 port may not offer sufficient power to external hard drives, the USB2HABMY6 can be connected to two ports on one PC to increase the power output to power the external device.
StarTech.com 6 ft USB Y Cable for External Hard Drive - USB A to mini B - USB cable - 1.8 m
USB cable
Length
1.8 m
Connector
2 x 4 pin USB Type A - male
Connector (Second End)
Mini-USB Type B - male
USB / USB 2.0
P/N: SAT1810U2, SLMSOPTB, PEXUSB7LP
USB cable
American Wire Gauge (AWG)
24/28
Length
1.8 m
Connector
USB / USB 2.0, RoHS
StarTech.com 1.8in USB to Micro SATA Hard Drive Enclosure, 7 Port PCI Express Low Profile High Speed USB 2.0 Adapter Card, USB to Slimline SATA CD/DVD Optical Drive Enclosure
76QV StarTech.com Mini USB to Micro USB Adapter In Stock £4.96
76QV StarTech.com 1 ft Mini USB 2.0 Cable - A to Mini B - M/M In Stock £3.16
76QV StarTech.com 3 ft USB Y Cable for External Hard Drive - USB A to mini B In Stock £3.68
76QV StarTech.com 6 ft USB Y Cable for External Hard Drive - USB A to mini B In Stock £3.88
76QV StarTech.com 3 ft Micro USB Cable - A to Right Angle Micro B In Stock £3.98
76QV StarTech.com 1ft Micro USB Cable - A to Micro B In Stock £3.68
76QV StarTech.com 6 ft Micro USB Cable A to Right Angle Micro B In Stock £4.78
Length: 1.8m
Price Range Ex VAT: 0 - 50
