StarTech.com 6 ft USB to DB25 Parallel Printer Adapter Cable - M/F
Quicklinx: 5CB6WS00 Mfr#: ICUSB1284D25
Length: 1.86m
Select:
  • Windows 8 (32/64 bits)
More than 50 in stock
£7.46 ex VAT
£8.95 inc VAT
Add a DB25 parallel port to your desktop or laptop PC through USB. The ICUSB1284D25 6 ft USB to DB25 parallel printer adapter cable turns an available USB port on a host PC into a DB25 female parallel port - allowing you to connect a DB25 printer to the computer as if the necessary parallel port was built-on.
A cost-effective and reliable solution, the USB to DB25 adapter saves the expense of replacing a parallel printer for the sake of USB capability.
StarTech.com 6 ft / 2m USB to DB25 Parallel Printer Adapter Cable - 2 Meter USB to IEEE-1284 Printer Cable - USB A to DB25 M/F (ICUSB1284D25) - parallel adapter
Parallel adapter
External
Interface (Bus) Type
USB 2.0
Ports
IEEE 1284
Length
1.86 m
Parallel
Data Transfer Rate
1.5 Mbps
Prolific PL-2305
Microsoft Windows 98 Second Edition, Microsoft Windows 2000, Apple MacOS X 10.4 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
Parallel adapter
External
USB 2.0
Ports
IEEE 1284
Wired
Parallel
Data Transfer Rate
1.5 Mbps
Processor / Memory
Prolific PL-2305
1 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25) - female
FCC, RoHS
Length
1.86 m
5CB6 StarTech.com 6 ft USB to Parallel Printer Adapter - M/M In Stock £9.00
5CB6 StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention In Stock £14.62
5CB6 StarTech.com 16 ft USB 2.0 Active Extension Cable - M/F In Stock £13.97
5CB6 StarTech.com 6 ft USB to DB25 Parallel Printer Adapter Cable - M/F In Stock £7.46
5CB6 StarTech.com 10 ft USB to Parallel Printer Adapter - M/M In Stock £17.83
Length: 1.86m
Price Range Ex VAT: 0 - 50
