StarTech.com 6 ft USB DVI Video Adapter
Quicklinx: 6PFXWS00 Mfr#: USB2DVIMM6
£71.07 ex VAT
£85.28 inc VAT
Connect a DVI display for an extended desktop multi-monitor USB solution using an all-in-one cable solution. The USB2DVIMM6 external USB DVI adapter cable offers a hassle-free multi-monitor solution, turning a USB 2.0 port into a DVI video connection. This 6-foot USB display adapter is a complete solution, ready to go out of the box with all the cables you need built right onto the adapter. Simply install the drivers, connect to your computer and display. Built-on cables make the USB2DVIMM6 easier to install and does away with the need to worry about forgetting a cable.
Instead of having to open the computer case to install a specialized video card to accommodate a multi-display configuration, USB2DVIMM6 functions as an external USB video card saving both time and hassle.
Multiple (USB2DVIMM6) adapters (up to 5 total) can be used on a single system to provide several mirrored displays or extended desktops - a convenient and cost-effective multi-VGA option for virtually any laptop or desktop operating environment.
StarTech.com 6 ft USB DVI External Multi Monitor Video Adapter Cable - USB A (M) DVI-D (M) - USB DVI Adapter - multiple display - external video adapter - DisplayLink DL-165 - 16 MB - black
External video adapter
Bus Type
USB 2.0
Graphics Engine
DisplayLink DL-165
16 MB
Max Resolution
1680 x 1050
DVI-D (Single-Link) (male connector)
4.8 cm 2.35 cm
Enclosure Colour
Bus Type
USB 2.0
Graphics Engine
DisplayLink DL-165
Max Resolution
1680 x 1050
Size
16 MB
Video Output
Supported Display Graphics
SVGA (800x600), UXGA (1600x1200), 1680x1050
Colours Max Resolution (external)
32-bit colour
Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Ubuntu 14.04, Windows 10 (32/64 bits), Ubuntu 16.04, Apple MacOS X 10.6 - 10.13.3, Google Chrome OS 51
Additional Requirements
SVGA monitor, USB port
System Requirements Details
Windows 2000/XP/Vista 1.2 GHz - RAM 512 MB - HDD 300 MB , MacOS X 10.4.11 - 10.5.6 1.2 GHz - RAM 512 MB - HDD 300 MB
1 x USB cable - 1.8 m
Plug and Play, FCC, RoHS
4.8 cm
2.35 cm
100 g
Enclosure Colour
6PFX StarTech.com DVI to VGA Cable Adapter - M/F In Stock £4.87
6PFX StarTech.com HDMI to DVI-D Video Cable Adapter - F/M In Stock £7.46
6PFX StarTech.com USB to VGA Multi Monitor External Video Adapter In Stock £31.82
Price Range Ex VAT: 50 - 100
