StarTech.com 6 ft USB 2.0 Extension Cable A to A - M/F
Quicklinx: 401LWS00 Mfr#: USBEXTAA_6
Length: 1.8m
16 in stock
£3.59 ex VAT
£4.30 inc VAT
This high quality 6ft USB A-A extension cable features one USB A male connector and one USB A female connector, extending the connection between USB 2.0 devices by up to 6 feet - an ideal solution for better placement of peripheral devices, or adding flexibility to existing USB ports. The USB extension cable is fully rated for use with USB 1.1 and USB 2.0 devices.
StarTech.com 6 ft USB 2.0 Extension Cable A to A - M/F - USB extension cable - 1.8 m
USB extension cable
Molded
Length
1.8 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type A - female
P/N: RKCONS2001GB, RACKCONS2001, DP2DVID, USB2IR2, 35FCREAD20, 35FCREAD20BK, CB100LANUSB2, USB555WG, 35FCREAD, 35FCREADBK, FCREADMINI, 35FCREADREM
USB extension cable
Molded
Length
1.8 m
Connector
StarTech.com 10/100 Ethernet + USB 2.0 Slot Saver CardBus Card, 20-in-1 3.5" Bay Flash Memory Card Reader, 35FCREAD, 35FCREADBK, 35FCREADREM, 7-in-1 USB 2.0 Multi Media Memory Card Reader, DisplayPort to DVI Dual Link Active Converter – USB Powered, High Res RackMount LCD Console for 19" Rack, USB to Infrared/IrDA SIR Adapter, USB Wireless Network Adapter
401L StarTech.com 6 ft Beige A to B USB 2.0 Cable - M/M In Stock £3.07
401L StarTech.com 3 ft Beige A to B USB 2.0 Cable - M/M In Stock £2.84
401L StarTech.com 6 ft USB 2.0 Extension Cable A to A - M/F In Stock £3.59
401L StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.90
401L StarTech.com USB A Gender Changer - F/F In Stock £3.81
401L StarTech.com 6 ft Beige A to A USB 2.0 Cable - M/M In Stock £3.42
401L StarTech.com 2 Port USB A Female Slot Plate Adapter In Stock £3.83
401L StarTech.com 6 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.15
401L StarTech.com 6 ft Clear A to B USB 2.0 Cable - M/M In Stock £3.15
Length: 1.8m
Price Range Ex VAT: 0 - 50
