StarTech.com 6 ft USB 2.0 Extension Cable A to A - M/F
Quicklinx: 401LWS00 Mfr#: USBEXTAA_6
This high quality 6ft USB A-A extension cable features one USB A male connector and one USB A female connector, extending the connection between USB 2.0 devices by up to 6 feet - an ideal solution for better placement of peripheral devices, or adding flexibility to existing USB ports. The USB extension cable is fully rated for use with USB 1.1 and USB 2.0 devices.
StarTech.com 6 ft USB 2.0 Extension Cable A to A - M/F - USB extension cable - USB (M) to USB (F) - 6 ft - molded - USBEXTAA_6 - USB extension cable - USB to USB - 1.8 m
USB extension cable
Molded
Length
1.8 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type A - female
P/N: RKCONS1901GB, UUSBOTG
USB extension cable
Molded
Length
1.8 m
Connector
