StarTech.com 6 ft USB 2.0 Certified A to B Cable - M/M
Quicklinx: 76QPWS00 Mfr#: USB2HAB6
Length: 1.8m
More than 50 in stock
£3.17 ex VAT
£3.80 inc VAT
This fully rated 6ft USB cable features one USB A male connector and one USB B male connector, providing a high quality connection to USB 2.0 peripherals. This USB 2.0 A-B cable is constructed of only top quality materials and expertly designed for durability.
StarTech.com 6 ft USB 2.0 Certified A to B Cable - M/M - USB cable - 1.8 m
USB cable
Molded
Length
1.8 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type B - male
USB / USB 2.0
P/N: PEXUSB400, SV231DPUA, SV231DPDDUA, IPUSB2HDMI, PEXUSB7LP, ST7200USBM, USBVGADOCK2, SV431DPUA, SV231HDMIUA, SAT3510U2FGB, SAT3510U2F, SV431DDVDUA, SV231DDVDUA, SV431DD2DUA, SV231DD2DUA, SV231DPU, CBUSB22, SV431DVIDGB, USBVGADOCKGB, ST7202USBGB, ST4202USBGB, SAT3510U2VGB, SAT3510U2V, PEX2EC35
USB cable
Molded
Length
1.8 m
Connector
USB / USB 2.0, FCC
StarTech.com 1 Port USB 2.0 & 2 Port FireWire ExpressCard Laptop Combo Adapter Card, 2 Port CardBus Laptop USB 2.0 PC Card Adapter, 2 Port ExpressCard Laptop USB 2.0 Adapter Card, 2 Port USB HDMI KVM Switch with Audio and USB 2.0 Hub, 2 Port USB to RS232 Adapter / 2 Port USB Hub, 3 Port PCI High Speed USB 2.0 Adapter Card, 3 Port PCI Low Profile High Speed USB 2.0 Adapter Card, 3 Port USB 2.0 Hub & 16-in-1 Multi Media Memory Card Reader, 3.5in Black Multi Port Panel for Front Drive Bay, 3.5in Silver FireWire 400 USB to IDE External Hard Drive Enclosure, 3.5in Silver USB 2.0 One Button IDE External Hard Drive Enclosure, 3.5in Silver USB 2.0 to Dual SATA JBOD External Hard Drive Enclosure, 3.5in USB FireWire SATA External Hard Drive Enclosure, 4 Independent Port PCI Express USB 2.0 Adapter Card, 4 Port CardBus Laptop USB 2.0 PC Card Adapter, 4 Port Dual DVI USB KVM Switch w/ Audio & USB Hub, 4 Port ExpressCard Laptop USB 2.0 Adapter Card, 4 Port PCI High Speed, 4 Port Silver USB 2.0 Hub, 4 Port USB 2.0 3 Port IEEE 1394a PCI USB Firewire Combo Adapter Card, 4 Port USB 2.0 Hub - Hub - 4 ports - Hi-Speed USB, 4-in-1 USB VGA Adapter and Docking Station, 5 Port PCI Express USB 2.0 Adapter Card, 5.25in Silver USB to IDE External Optical Drive Enclosure, 6-in-1 Black USB 2.0 Laptop Docking Station / Port Replicator, 7 Port PCI Express Low Profile High Speed USB 2.0 Adapter Card, 7 Port USB 2.0 Hub – Portable and Compact – Bus Powered USB 2.0 Extender – USB Multiport Expander (ST7202USB), CB330USB2, Dual Profile PCI Express to 34mm and 54mm ExpressCard Adapter Card, Ethernet or USB to HDMI Converter, PCI Express to ExpressCard Adapter - Front Bay, USB 2.0 to SATA adapter, USB Powered Laptop Cooler with 2 Built in Fans , StarTech.com InfoSafe 1.8" USB 2.0 CE IDE Hard Drive Enclosure, 3.5" eSATA & USB 2.0 SATA Drive Enclosure, 3.5" USB 2.0 SATA Aluminum HD Enclosure , StarTech.com StarView DVI/VGA USB KVM Switch with Audio
76QP StarTech.com 15 ft USB 2.0 A to B Cable - M/M In Stock £4.33
76QP StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.90
76QP StarTech.com 6 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.17
76QP StarTech.com 10m/30ft Active USB 2.0 A to B Cable - M/M In Stock £16.43
76QP StarTech.com 20m / 65 ft Active USB 2.0 A to B Cable - M/M In Stock £29.16
76QP StarTech.com 15m / 50 ft Active USB 2.0 A to B Cable - M/M In Stock £25.76
Length: 1.8m
Price Range Ex VAT: 0 - 50
