This fully rated 6ft USB cable features one USB A male connector and one USB B male connector, providing a high quality connection to USB 2.0 peripherals. This USB 2.0 A-B cable is constructed of only top quality materials and expertly designed for durability.
- StarTech.com 6 ft. (1.8 m) USB Printer Cable - USB 2.0 A to B - Printer Cable - Black - USB A to B (USB2HAB6) - USB cable - USB to USB Type B - 1.8 m
- USB cable
- Molded
- Length
- 1.8 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 4 pin USB Type B - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: ICUSB2324I, IPUSB2HD3, IPUSB2VGA2, PM1115UW, PM1115UWEU, RKCOND17HD, ST12MHDLANU, ST12MHDLANUR, ST4200MINI2, SV231DPDDUA2, SV231TDVIUA, SV431DL2DU3A, SV431DPDDUA2, SV431DPUA2, SV431TDVIUA, SV565UTPDUV, SV565UTPHDU, USB2001EXT2, USB2001EXT2NA, USB2002EXT2NA, USB2004EXT2NA, USB3EXT6INBK
- USB cable
- Molded
- Length
- 1.8 m
- Black
- Connector
- USB / USB 2.0, FCC
- Designed For
- P/N: ICUSB2324, ICUSB2324I, IPUSB2HD3, IPUSB2VGA2, PCI420USB, PCI625USB2I, PCIUSB7, PEXUSB4DP, PM1115UW, PM1115UWEU, RKCOND17HD, ST12MHDLANU, ST12MHDLANUR, ST4200MINI, ST4200MINI2, ST4200USBM, ST4202USB, ST4202USBGB, ST7200USBM, ST7202USB, ST7202USBGB, SV231DD2DUA, SV231DDUSB, SV231DDVDUA, SV231DPDDUA, SV231DPDDUA2, SV231DPU, SV231DPUA, SV231DVIDDU, SV231HDMIUA, SV231QDVIUA, SV231TDVIUA, SV231USB, SV431DD2DUA, SV431DDUSB, SV431DDVDUA, SV431DL2DU3A, SV431DPDDUA2, SV431DPUA, SV431DPUA2, SV431DVIDDU, SV431TDVIUA, SV431USB, SV565USAGB, SV565UTPDUV, SV565UTPHDU, SV831DVIU, USB1000IP, USB2001EXT2, USB2001EXT2NA, USB2002EXT2, USB2002EXT2NA, USB2004EXT2, USB2004EXT2NA, USB3EXT6INBK, USB421, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBFAA_6, USBPLATE4, USBVGADOCK2, UUSBUSBBMF
StarTech.com Mountable 4 Port Rugged Industrial USB Hub | In Stock | £61.41 |
StarTech.com 1 ft Panel Mount USB Cable B to B - F/M | In Stock | £5.68 |
StarTech.com Mountable Rugged Industrial 7 Port USB Hub | In Stock | £86.37 |
StarTech.com 10m/30ft Active USB 2.0 A to B Cable - M/M | In Stock | £20.17 |
StarTech.com 20m / 65 ft Active USB 2.0 A to B Cable - M/M | In Stock | £37.87 |
StarTech.com 15m / 50 ft Active USB 2.0 A to B Cable - M/M | In Stock | £33.33 |
StarTech.com 3 ft Panel Mount USB Cable B to B - F/M | In Stock | £5.69 |
