Extend your USB 3.0 SuperSpeed cable an additional 6 feet. The USB3SEXTAA6 SuperSpeed USB 3.0 extension cable (1.8m, A-A), offers a durable, high quality connection that harnesses the full capability of the USB 3.0 standard.
Designed for next-generation SuperSpeed USB device connections, this USB 3.0 male to female cable extends a USB 3.0 cable connection by up to 1.8 meters and delivers the full USB 3.0 bandwidth of 5Gbps, supporting maximum throughput between compatible devices when used with a USB 3.0 host and device.
The USB 3.0 extension cord features high quality Shielded Twisted Pair (STP) construction, helping to prevent electromagnetic interference and ensuring reliable data communication.
- StarTech.com 6 ft SuperSpeed USB 3.0 Extension Cable A to A - M/F - 2m USB 3 Extension Cable (USB3SEXTAA6) - USB extension cable - USB Type A to USB Type A - 1.8 m
- Technology
- Shielded twisted pair (STP)
- Length
- 1.8 m
- Connector
- 9 pin USB Type A - male
- Connector (Second End)
- 9 pin USB Type A - female
- USB 3.0
- Limited lifetime warranty
- Designed For
- P/N: 2SD4FCRU3, CFASTRWU3, ECUSB3S11, ECUSB3S22, ECUSB3S254F, FCREADMICRO3, HB20A4AME, HB20A7AME, MPEXUSB3S22B, MSDREADU3CA, S355BU33ERM, ST4300USB3, ST4300USB3EU, ST4300USB3GB, ST4300USBM, USB3SAA3MBK
- Technology
- Length
- 1.8 m
- Connector
- USB 3.0
- Designed For
StarTech.com 10 ft SuperSpeed USB 3.0 Cable A to B - M/M | In Stock | £7.60 |
StarTech.com 3 ft SuperSpeed USB 3.0 Cable A to B - M/M | In Stock | £2.92 |
StarTech.com 6 ft SuperSpeed USB 3.0 Cable A to B - M/M | In Stock | £4.88 |
StarTech.com 6 ft SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.21 |
