Connect two DB9 equipped serial devices. This 6ft Straight through Serial cable features two DB9 female (DB9F) connectors, offering a convenient and reliable serial connection.
- StarTech.com 6 ft Straight Through Serial Cable - DB9 F/F - Serial cable - DB-9 (F) to DB-9 (F) - 6 ft - MXT100FF - serial cable - DB-9 to DB-9 - 1.8 m
- Serial cable
- Length
- 1.8 m
- Connector
- 9 pin D-Sub (DB-9) - female
- Connector (Second End)
- Limited lifetime warranty
- Designed For
- P/N: EC1S232U2, ICUSB23208FD, ICUSB23216FD, ICUSB2324852, ICUSB232C, ICUSB232INT1, ICUSB232INT2, ICUSB232PROC, ICUSB232SM3, ICUSBANDR232, MPEX2S1P552, MPEX4S552, PCI2S4851050, PCI4S954PW, PEX1S1P952, PEX1S553LP, PEX1S953LP, PEX2S1050, PEX2S1P553B, PEX2S553, PEX2S553LP, PEX4S553, PEX4S553B
- Serial cable
- Length
- 1.8 m
- Connector
- Designed For
- P/N: 10PKPCI1S550, EC1S232U2, IC485S, ICUSB23208FD, ICUSB23216FD, ICUSB2324852, ICUSB2328, ICUSB232C, ICUSB232DB25, ICUSB232INT1, ICUSB232INT2, ICUSB232PROC, ICUSB232SM3, ICUSB422, ICUSBANDR232, MPEX2S1P552, MPEX4S552, PCI1S550, PCI2S1P, PCI2S232485I, PCI2S4851050, PCI2S550, PCI2S550_LP, PCI2S950, PCI4S550, PCI4S954PW, PEX1S1P952, PEX1S553LP, PEX1S952LP, PEX1S953LP, PEX2S1050, PEX2S1P553B, PEX2S553, PEX2S553LP, PEX4S553, PEX4S553B, PEX4S952
