Product
StarTech.com 6 ft Straight Through Serial Cable - DB9 F/F
Quicklinx: 3ZN0WS00 Mfr#: MXT100FF
Length: 1.8m
Type: Serial
38 in stock
£3.65 ex VAT
£4.38 inc VAT
Standard delivery Delivered within 3-5 working days
Connect two DB9 equipped serial devices. This 6ft Straight through Serial cable features two DB9 female (DB9F) connectors, offering a convenient and reliable serial connection.
StarTech.com 6 ft Straight Through Serial Cable - DB9 F/F - serial cable - 1.8 m
Serial cable
Length
1.8 m
Connector
9 pin D-Sub (DB-9) - female
Connector (Second End)
StarTech.com 1, 16, 2, 2 Serial/1, 2S1P, 4, 8, PCI1S650DV, PCI2S650DV, PCI2S650PW, PCI4S650DV
Serial cable
Length
1.8 m
Connector
StarTech.com 1 Port CardBus PCMCIA Parallel Laptop Adapter Card, 1 Port ExpressCard RS232 Serial Adapter Card with 16950 UART, 1 Port ISA RS232 Serial Adapter Card with 16550 UART, 1 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART, 1 port Native PCI Express RS232 Serial Adapter Card with 16550 UART, 1 Port PCI Dual Voltage Parallel Adapter Card, 1 Port PCI Low Profile RS232 Serial Adapter Card with 16550 UART, 1 Port PCI RS232 Powered Serial Adapter Card, 1 Port PCI RS232 Serial Adapter Card w/ 16950 UART - Dual Voltage, 1 Port PCI RS232 Serial Adapter Card with 16550 UART, 16 Port Low Profile RS232 PCI Express Serial Card - Cable Included, 2 Port 16650 PCI-E WHQL Approved Serial Card, 2 Port ExpressCard Serial Adapter Card, 2 Port ISA RS232 Serial Adapter Card with 16550 UART, 2 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART, 2 Port Native PCI Express RS232 Serial Adapter Card with 16550 UART, 2 Port PCI Express RS232 Serial Adapter Card with 16550 UART, 2 Port PCI RS232 Serial Adapter Card w/ 16950 UART - Dual Voltage, 2 Port PCI RS232 Serial Adapter Card with 16550 UART, 2 Port RS232/422/485 PCI Serial Adapter Card w/ ESD Protection, 2 Port USB to RS232 Adapter / 2 Port USB Hub, 2 Serial/1 Parallel Port Dual Voltage WHQL PCI Card, 2S1P PCI Serial Parallel Combo Card with 16550 UART, 4 Port ExpressCard 16C950 Serial Card, 4 Port Low Profile Native RS232 PCI Express Serial Card with 16950 UART, 4 Port PCI Dual Profile RS232 Powered Serial Adapter Card, 4 Port PCI Express RS232 Serial Adapter Card with 16950 UART, 4 Port PCI Express Serial Card, 4 Port PCI Express WHQL Approved Serial Card, 8 Port Low Profile RS232 PCI Serial Card with 16950 UART, PCI1S650DV, PCI2S650DV, PCI2S650PW, PCI4S650DV
Length: 1.8m
Type: Serial
Price Range Ex VAT: 0 - 50
