StarTech.com 6 ft Slim High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable
Quicklinx: 7RWQWS00 Mfr#: HDMIMM6HSS
Length: 1.8cm
More than 50 in stock
£7.94 ex VAT
£9.52 inc VAT
Create Ultra HD connections between your HDMI-enabled devices with minimal clutter; supports Ethernet Data Channel. The HDMIMM6HSS 6-foot Slim High Speed HDMI Cable supports advanced capabilities, including Ethernet data inter connectivity with compatible HDMI-capable devices, and features a thin cable design (3.5mm in diameter).
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com High Speed HDMI cables are expertly designed and constructed of only top quality materials to ensure high quality and high definition performance.
StarTech.com 6 ft Slim High Speed HDMI Cable with Ethernet Ultra HD 4k x 2k - HDMI with Ethernet cable - 1.8 cm
Cable
American Wire Gauge (AWG)
36
Length
1.8 cm
Connector
HDMI - male
Connector (Second End)
HDMI - male
HDMI Ethernet Channel (HEC)
Cable Type
36
Jacket Material
PVC
Length
1.8 cm
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
7RWQ StarTech.com 10 ft Flat High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable In Stock £8.85
7RWQ StarTech.com 15 ft High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable In Stock £16.11
7RWQ StarTech.com 20 ft High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable In Stock £31.80
7RWQ StarTech.com 6 ft Flat High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable In Stock £6.94
7RWQ StarTech.com 6 ft High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable HDMI to HDMI M/M In Stock £7.82
Length: 1.8cm
Price Range Ex VAT: 0 - 50
