Create Ultra HD connections between your HDMI-enabled devices with minimal clutter; supports Ethernet Data Channel. The HDMIMM6HSS 6-foot Slim High Speed HDMI Cable supports advanced capabilities, including Ethernet data inter connectivity with compatible HDMI-capable devices, and features a thin cable design (3.5mm in diameter).
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com High Speed HDMI cables are expertly designed and constructed of only top quality materials to ensure high quality and high definition performance.
- StarTech.com 6ft Slim HDMI Cable, 4K High Speed HDMI Cable with Ethernet, 4K 30Hz UHD HDMI Cord, 10.2 Gbps Bandwidth, 4K HDMI 1.4 Video / Display Cable M/M, 36AWG, ARC, HDCP 1.4, CEC - Durable Thin HDMI Cable - HDMI cable with Ethernet - 1.8 cm
- Cable
- American Wire Gauge (AWG)
- 36
- Length
- 1.8 cm
- Black
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- HDMI Ethernet Channel (HEC)
- Limited lifetime warranty
- Designed For
- P/N: LENYMCHDVUGK, SV431DHD4KU, SV431HDU3A2
- Cable Type
- 36
- Jacket Material
- PVC
- Length
- 1.8 cm
- Plated Connector
- Gold
- Black
- Connector
- 19 pin HDMI Type A - male
- RoHS
- Limited warranty - lifetime
- Designed For
