StarTech.com 6 ft Slim High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable
Quicklinx: 7RWQWS00 Mfr#: HDMIMM6HSS
Create Ultra HD connections between your HDMI-enabled devices with minimal clutter; supports Ethernet Data Channel. The HDMIMM6HSS 6-foot Slim High Speed HDMI Cable supports advanced capabilities, including Ethernet data inter connectivity with compatible HDMI-capable devices, and features a thin cable design (3.5mm in diameter).
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com High Speed HDMI cables are expertly designed and constructed of only top quality materials to ensure high quality and high definition performance.
StarTech.com 6ft Slim HDMI Cable, 4K High Speed HDMI Cable with Ethernet, 4K 30Hz UHD HDMI Cord, 10.2 Gbps Bandwidth, 4K HDMI 1.4 Video / Display Cable M/M, 36AWG, ARC, HDCP 1.4, CEC - Durable Thin HDMI Cable - HDMI cable with Ethernet - 1.8 cm
Cable
American Wire Gauge (AWG)
36
Length
1.8 cm
Connector
HDMI - male
Connector (Second End)
HDMI - male
HDMI Ethernet Channel (HEC)
P/N: LENYMCHDVUGK, SV431DHD4KU, SV431HDU3A2
Cable Type
36
Jacket Material
PVC
Length
1.8 cm
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
