Connect HDMI Mini-equipped devices to displays incorporating HDMI technology, with minimal clutter, maximum quality and Ethernet Data Channel Support. The HDMIACMM6S 6-foot Slim High Speed HDMI to HDMI Mini cable supports advanced capabilities including Ethernet data interconnectivity with compatible HDMI-enabled devices, and features a thin cable design (3.5mm in diameter) suitable for installations with tight space requirements.
This High Speed HDMI to HDMI Mini cable lets you connect devices with an HDMI Mini (type C) port to a display/device with an HDMI (type A) port - a cost-saving solution for connecting cutting-edge and next-generation HDMI-capable devices to existing HDMI technology.
The HDMI/HDMI Mini cable features high quality gold-tipped connectors that ensure peak connectivity.
- StarTech.com 6 ft High Speed HDMI Cable with Ethernet- HDMI to HDMI Mini- M/M (HDMIACMM6S) - HDMI with Ethernet cable - 1.8 m
- Cable
- American Wire Gauge (AWG)
- 36
- TMDS Links
- Single link
- Length
- 1.8 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- Mini HDMI - male
- Limited lifetime warranty
- Cable Type
- 36
- TMDS Links
- Single link
- Jacket Material
- PVC
- Length
- 1.8 m
- Plated Connector
- Gold
- Black
- Connector
- 19 pin HDMI Type A - male
- 19 pin mini HDMI Type C - male
- RoHS
- Limited warranty - lifetime
