StarTech.com 6 ft Slim High Speed HDMI Cable with Ethernet - HDMI to HDMI Mini M/M
Quicklinx: 7NYCWS00 Mfr#: HDMIACMM6S
Connect HDMI Mini-equipped devices to displays incorporating HDMI technology, with minimal clutter, maximum quality and Ethernet Data Channel Support. The HDMIACMM6S 6-foot Slim High Speed HDMI to HDMI Mini cable supports advanced capabilities including Ethernet data interconnectivity with compatible HDMI-enabled devices, and features a thin cable design (3.5mm in diameter) suitable for installations with tight space requirements.
This High Speed HDMI to HDMI Mini cable lets you connect devices with an HDMI Mini (type C) port to a display/device with an HDMI (type A) port - a cost-saving solution for connecting cutting-edge and next-generation HDMI-capable devices to existing HDMI technology.
The HDMI/HDMI Mini cable features high quality gold-tipped connectors that ensure peak connectivity.
StarTech.com 6 ft High Speed HDMI Cable with Ethernet- HDMI to HDMI Mini- M/M (HDMIACMM6S) - HDMI cable with Ethernet - 1.8 m
Cable
American Wire Gauge (AWG)
36
TMDS Links
Single link
Length
1.8 m
Connector
HDMI - male
Connector (Second End)
19 pin mini HDMI Type C - male
Cable Type
36
TMDS Links
Single link
Jacket Material
PVC
Length
1.8 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
