The SIMPLEUPS06 6-foot Simple Signaling Serial UPS cable features 1 DB9 male connector and 1 DB9 female connector, allowing you to communicate from your computer, work station or server to your UPS power supply. This cost-effective Serial UPS cable can be used as a direct replacement to the AP9823.
- StarTech.com Simple Signaling Serial UPS Cable AP9823 - serial cable - 1.8 m
- Serial cable
- Length
- 1.8 m
- Connector
- 9 pin D-Sub (DB-9) - male
- Connector (Second End)
- 9 pin D-Sub (DB-9) - female
- Grey
- Limited lifetime warranty
- Serial cable
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 1.8 m
- Grey
- Connector
- RoHS
