Only best-quality components are used when StarTech.com's expert manufacturing team creates its cabling and this cable is not different. Connect a data switch or PC to a parallel printer with the StarTech.com PB10, a standard printer cable. This product helps StarTech.com maintain its tradition of offering top-notch parts and products for the best price possible.
StarTech.com 6 ft DB25 to Centronics 36 Parallel Printer Cable - M/M - Printer cable - DB-25 (M) to 36 pin Centronics (M) - 6 ft - PB6_ - printer cable - 1.8 m
Printer cable
Length
1.8 m
Connector
DB-25 - male
Connector (Second End)
36 PIN Centronics - male
P/N: EC1PECPS, PCI1P_LP, PCI1PECP, PCI2PECP, PCI2S1P, PCI2S1P2, PEX1P, PEX1P2, PEX1PLP, PEX2PECP2
Printer cable
Length
1.8 m
Connector
25 pin D-Sub (DB-25) - male
