Attach a PC VGA port to a switchbox. This 6-foot VGA Video Monitor Cable features two HDDB15 (male) connectors, providing a high quality VGA connection.
The cable supports a maximum video resolution of up to 800x600. For applications that require higher resolutions, see 6ft Coax VGA Cable (MXT101MMHQ).
- StarTech.com 6 ft. (1.8 m) VGA to VGA Cable - HD15 VGA Cable - 800x600 Resolution - Male/Male - VGA Monitor Cable (MXT101MM) - VGA cable - 1.8 m
- VGA cable
- Technology
- Shielded
- Length
- 1.8 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- Grey
- Limited lifetime warranty
- Designed For
- P/N: CDP2VGA, CDP2VGAUCPW, MDP2VGAAMM2M, MDP2VGAAMM3M, SV231DVGAU2A, SV431DVGAU2A, USB32VGAEH3
- VGA cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 1.8 m
- Grey
- Connector
- 15 pin HD D-Sub (HD-15) - male
- Designed For
StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M | In Stock | £5.82 |
StarTech.com 10 ft VGA Monitor Cable - HD15 MM | In Stock | £4.48 |
StarTech.com 15 ft Monitor VGA Cable - HD15 MM | In Stock | £5.07 |
StarTech.com 20 ft Coax High Resolution Monitor VGA Cable HD15 M/M | In Stock | £9.79 |
StarTech.com 1 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M | In Stock | £5.99 |
