StarTech.com 6 ft Monitor VGA Cable - HD15 M/M
Quicklinx: 3ZK3WS00 Mfr#: MXT101MM
Type: VGA
Length: 1.8m
Select:
More than 50 in stock
£4.11 ex VAT
£4.93 inc VAT
Attach a PC VGA port to a switchbox. This 6-foot VGA Video Monitor Cable features two HDDB15 (male) connectors, providing a high quality VGA connection.
The cable supports a maximum video resolution of up to 800x600. For applications that require higher resolutions, see 6ft Coax VGA Cable (MXT101MMHQ).
StarTech.com 6 ft Monitor VGA Cable - HD15 M/M - VGA cable - 1.8 m
VGA cable
Shielded
Length
1.8 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
Grey
P/N: DP2VGA3, HD2VGAE2, HD2VGAMICRO, MCHD2VGAE2, MDP2VGA2, MNHD2VGAE2, USB32VGAEH3, USB32VGAES, USB32VGAPRO
VGA cable
Shielded
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
1.8 m
Grey
Connector
3ZK3 StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £6.05
3ZK3 StarTech.com 10 ft VGA Monitor Cable - HD15 MM In Stock £4.46
3ZK3 StarTech.com 15 ft Monitor VGA Cable - HD15 MM In Stock £5.03
3ZK3 StarTech.com 20 ft Coax High Resolution Monitor VGA Cable HD15 M/M In Stock £9.79
3ZK3 StarTech.com 1 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £4.72
Type: VGA
Length: 1.8m
Price Range Ex VAT: 0 - 50
